fuel cut tips
combz
nah calvin, it stillw asnt working before my seal blew on my crank, which i have yet to repair. i tried mbar at 225, 235, 240. if you look at my logs, my mbar would go to like 213 ish when i let off the gas..then it just ocasionally blips to 225...and fuel cut flickers, then it goes back to 215mbar ish.. and fuel cut goes back on. whats strange is that it seems like fuel cut was ignoring what i set the mbar value to..like if i set it to 235...fuel cut would still flick off when i hit 225mbar in my logs. Strange behaviour. its in my logs, increase zoom and have a look.
this is very strange... I'll test in a car myself later. i did already and it worked. you have 2 fuel cuts i described it somewhere.
does anyone else have a datalog where when u let off gas, mbar goes to say 195-215 ish...then suddenly blips to 225 ish..and causes fuel cut to disable. also what should \"Above (minimum) rpm\" be set to? like shouldnt this be like 1200rpm or something...because say your in fifth gear and you slow the car down alot, won't fuel cut stop working if rpm goes below this min rpm? and \"fuel cut restore\" can both of these be explain calvin? and how they work together? you should def have another look at this datalog im going to post. i cant post my log for some reason right now..saying connection timing out..its the log i posted a few times back called \"fuelcutsometimesworking.elf\"
it's rom 63 I have noticed the people that are Authorized Ectuners are not having any issues and the people who are not (Pro-Users Single car License) are having issues. Is it possible that Pro Version has a bug and the tuner version does not? Because I know it's not something I did...up to until these last few updates the Fuel Cut worked perfect.
- JimTry32_EBC_ClosedLoopTry19.cal
- (8.19 KiB) Downloaded 799 times
- NONFuelCut.elf
- (1.69 MiB) Downloaded 816 times
min rpm, fuelcut will only start working above that rpm restore rpm, if a fuelcut is active the fuel will be restored below that rpm. e.g. only works above 2000 rpm once active it will restore fuel belove 1200 rpmcombz wrote:does anyone else have a datalog where when u let off gas, mbar goes to say 195-215 ish...then suddenly blips to 225 ish..and causes fuel cut to disable. also what should "Above (minimum) rpm" be set to? like shouldnt this be like 1200rpm or something...because say your in fifth gear and you slow the car down alot, won't fuel cut stop working if rpm goes below this min rpm? and "fuel cut restore" can both of these be explain calvin? and how they work together? you should def have another look at this datalog im going to post. i cant post my log for some reason right now..saying connection timing out..its the log i posted a few times back called "fuelcutsometimesworking.elf"
