Stock B18CR 96'spec on some spray
				wolve
let's throw this graph up for shits and giggles now it's of the road again till next season    -totally stock JDM B18CR 96'spec  -stock cast 4-2-1 exhaustmani with 2.25\" collector  -stock intake mani and tb  -WAI with Apexi filter  -full 2.5\" SS magnaflow/kteller exhaust combo  -680cc precision injectors  -inline bosch 044 pump  -conservative progressive nitrous shot  -tuned by me on ectune offcourse
 (straight 98RON pump gas, no additives, this is like USA 94 octane
 )      13.6@104mph unprepped airfield on streettires (all motor)  13.3@103mph prepped track on streettires (all motor)  12.3@119mph prepped track on streettires (on spray, need traction/slicks
 )    193whp all motor  319whp on spray (activation at 6000rpm, dynapack needed 300rpm to catchup
 ) needed finetuning on the track
- dynowhp.jpg (1.48 MiB) Viewed 40885 times
						your kidding right? i listed the complete setup in the first post and you're asking what the setup ispullig wrote:what's the setup ? do u mind sharing the all motor tune so I can get an idea on timing for his
- Garrett
stock rod and pistons
     progressive Nitrous help a lot I think
									eCtune Team  eCtune Authorized Tuner  Location: Riviere-du-Loup, Quebec, Canada    www.precisionautocanada.com
						that was the next dynotrip after that dreaded lag in update:Pcalvin wrote:good good stuff wolve;)
it's all in a daily driven eg coupe on oldold crusty yoko advan's(old as in they have been lying outside/in shed for 2 yearsOh I'm sorry I should have been more clear. I was wanting to know the setup as in what chassis and slicks? Fully gutted that kinda thing
nice meeting you toWe want to see your .cal! haha, great result! It was nice to meet you 2 weeks ago
progressive is keystock rod and pistons progressive Nitrous help a lot I think
      ahh well, next season bigger/better things aiming for 400-450whp and high tens i don't know where the p73 map in ectune derrives from but... i choose not to run it because timing was way to agressive for my taste if it's actually the factory map (itr only came obd2) keep in mind the itr has a knock sensor onboardpullig wrote:Only 23 Degres timing? im using the stock p73 map on his itr and it runs the car good just doesnt seem to have to good top end... The timing for it is 28 degrees should i try lowering the timing to see if it leans out ? i mean 28 and 23 degrees is a pretty big difference
- Garrett
the WOT timing really look like the timing I use on our realtime Acura Type R with pro2 cams    when I adjust the timing without any pre-detonation, I reduce the timing of 12 degrees and the engine gave me 8 whp more
						Interesting timing and REALLY good power and drag times for a stock ITR motor  I also run a EG coupe with removed seats and do a 13.6 @101mph with hoosier DOT drag radials 225/50/15  my motor has hytech style headers  buddy club pro spec III 2.5\" system  crank scraper  bored TB to 65mm  intake gasket,  189whp    crome timing from 28-33 degrees with 98RON.    amazing you are getting those trap speeds and times with the stock motor, must be a great motor. Most of the ITR's i tune put out 180-190whp no matter what i try.
						yeah i was like : something's not right at first to, cause i knew 104mph and factory 200-205bhp was not adding upCoupe-r wrote:Interesting timing and REALLY good power and drag times for a stock ITR motor I also run a EG coupe with removed seats and do a 13.6 @101mph with hoosier DOT drag radials 225/50/15 my motor has hytech style headers buddy club pro spec III 2.5" system crank scraper bored TB to 65mm intake gasket, 189whp crome timing from 28-33 degrees with 98RON. amazing you are getting those trap speeds and times with the stock motor, must be a great motor. Most of the ITR's i tune put out 180-190whp no matter what i try.
12.3@119mph nitrous-assisted grocery getter on street tires
  193whp allmotor and 320whp on the funny gas
