Cold start AFR's always changing............
Post by thething96 »
Does not mater how many times I adjust ect and iat compensations, cold start afr's are always different from day to day. Specially when it's warm and I start the car. afr's tend to be at 17.5-18.0, and when it warms up, it's around 13.5. I've always had this issue. It was worse before, but after changing the iat sensor, it got a little better, but problem has always been there. I've adjusted compensations in any way possible, but no luck. Am I doing something wrong? Is anyone else having the same issue? Thanks............
b20beast
Post by b20beast »
Did you tune your batter offset tables? Can you post your cal and bin?
Yes, I did adjust battery offsets. Car is running RC550 high impedence injectors. At first, I used the original offset provided by ectune for those injectors, but ended up changing a little anyway. As soon as I get a chance, I'll post cal. Thanks....................
Here's the latest cal. This one seems to be better, but still not very stable...
new.calibration.code.16.fix.cal
(8.19 KiB) Downloaded 280 times
By the way, setup is 98 USDM Type r, JRSC at 11 psi or so, CP 10.5.1 pistons, oem rods, arp rod, main and head studs, hondata intake gasket, all oem gaskets.......
b20beast
Post by b20beast »
need the map as well
Excuse my neewbieness, but what map are you talking about?
Played with closeloop a little. Have it set that at 1200rpm, closeloop in at 0%, out at 1%. AFR's got better, but are fluctuating between 13.8-15.1. Any help is greatly appreciated. Thanks.......................
Is there anyone out there that can help me out? Please, this problem is very anoying. Had the car tuned with other software and it would never do this. Don't know what the problem is. Thanks...............
Start a new cal from scratch and get the car started using the Injector Calibration tool in the tools drop down let the car warm and adjust battery offset. Let the car cool and then adjust ECT/IAT corrections. That's how I go about it and never have an issue. You adjusted the fuel table which is probably why it's not so stable.
Thanks for the tip. I actually did that, but the other way around(adjusted cold tables, then warm). Will make a new cal and follow your steps. Will post soon............
I guess adjusting warm compensations first and cold later made a difference. The car still tends to lean out, but not as bad, and for about 10 seconds only. Thank you very much..
