Playing with Auto Tune
FreshDA9
Post by FreshDA9 »
So i was trying the Auto tune feature and it went crazy on me. have settings set to 14.7 all of a sunday went to 16.9 then shot down to 10.1. Sorry i dont have a Data log of when it happened. i can get one if needed. Current Settings - Disabled Closed loop and VE Correction - A/F Overlay Low 14.7, Med 13, High 11.5 on Primary & Secondary maps. - WideBand is matching on ectune. for the rest of the settings i have a pic i put up as an attachment. i might have it the comands on the over run off also by mistake? thank you guys.
Overlay Ectune.JPG (159.7 KiB) Viewed 10876 times
since when did we get auto tune?
FreshDA9
Post by FreshDA9 »
the auto adjust for the target A/F?
Auto Adjust selection based on wideband reading and target afr
this is quoted from the features section on the main page. or Ctrl+Alt+A is the short key.
its a cell by cell function, and you have to hold the cell steady and let everything stabalise before you apply it. Also you must be dead in the center of a cell or it won't be acurate.. Best not to use it right now, probably improve on this in the future.
FreshDA9
Post by FreshDA9 »
Bugermass wrote:its a cell by cell function, and you have to hold the cell steady and let everything stabalise before you apply it. Also you must be dead in the center of a cell or it won't be acurate.. Best not to use it right now, probably improve on this in the future.
hmm good to know. i knew it was cell to cell im trying to figure out how it threw it self lean then rich. maybe it wasnt in the center like you said .
it's not auto-tune... that is how the average afr for the cells are stored
