2nd time on a other dyno and colder wether:
Tri-Y header loves a low vtec engagement.... try it! I've made a custom ign map for VTec. As you can see, it works! Most of the time i also use 5250/5300, but this one didn't liked it at all!Coupe-r wrote:whats up with the low vtec pont? all the b18cr's I tune love it at 5250 rpm. My b18cr is around 190whp so figures are on par. What are others vtec point on stock B18cr with similar mods?
The last dyno was a cheap ass dyno... here is the vid: CLICK People around the car said it was bouncing on the dyno.... Anyway... If i raise the vtec it won't go any faster, but slower! I've tested several times....xenocron wrote:You can see the dip in power at 4500 in those graphs...I would raise it personally.
Faster on what?Civic VTI-Turbo wrote:The last dyno was a cheap ass dyno... here is the vid: CLICK People around the car said it was bouncing on the dyno.... Anyway... If i raise the vtec it won't go any faster, but slower! I've tested several times....xenocron wrote:You can see the dip in power at 4500 in those graphs...I would raise it personally.
Are you running eCtune now? No more Crome?Coupe-r wrote:i have a tri y header and still haven't seen vtec needing to come in that low? faster on what? i guess at the end of the day when racing you are NEVER below 5k (well for me 6.5k-7k) like tp hear from others with an ITR?
