Ectune encountered a problem, needs to close. please help.
				butch11a
my usb cable frpm the ecu to pc got pulled yesterday while ectune was running, tried to reconnect and it didn't connect, so i restarted the pc and got this error. Addl'l info, windows xp, moates hulog n ostrich 2, lc-1 all on a usb hub.    tried reinstalling ectune and deleting in4tecsoln already and it didn't work, pls help, tnx
- ectunescrnerror1.jpg (51.89 KiB) Viewed 11494 times
- ectunescrnerror2.jpg (32.96 KiB) Viewed 11494 times
I normally just try to 'continue' through the errors when you get them, some you have to restart ectune, but most don't seem to effect ectune after you click 'continue'.
It's not that big of a deal. You should have the original ectune file(which should be saved under documents, and you probably had to use winrar archiver). The way I did it is to remove ectune under control panel/add or remove software. After that, I went to my documents, uploaded ectune again, did a web update, and presto!!!!! I'm not sure if you'll have to do that.......
						tried what you said and i got the locked message telling me to update to the latest version, when i did a force update same thing happened, i got the same error as before, ectune encountered a problem and needs to close, i hope someone has an idea what else i can do, thanks anyways....
