datalogger says it is recording but nothing
- jpjackson
by the way
by the way i spent the last hour on the forum trying to find someone else having this problem, i found nothing even similar to my problem. what am i doing wrong?
screen shot
OK hears my screen shot. i figured it out
- ect screen shot.JPG (239.76 KiB) Viewed 8968 times
RE
here is another log i recorded that isn't playing back. the file size on this one is 4.29mb, i recorded for about 20 minuets on my way home from work.
- work dammit_13112009_1638_13112009_1712.elf
- (4.29 MiB) Downloaded 381 times
RE
wow thats weird. then why wont it play on mine? im running a sohc zc, turboxs t3 variant, 3inch down pipe,2.5 inch charge pipes, msd, nippon racing low comp pistons,guessing 8.5:1, eagle h-beams, block guard, arp head studs, stock head, everything fully balanced, dsm 450cc, NOS direct port fogger, walbro 225, b@m fpr(50psi@WOT). i think that is about it. so what do you think my problem is? should i try to reinstall ectune? will the licences i got for the first install still work? i dont know why the data is all out of wack like that, im only boosting 8 psi. im lost. PLEASE HELP
I've been having issues with ectune as well. The reason I asked if you had an ostrich is because to me it feels that some pro-ostrich ectune programs may be off. The very first time I used ectune, it was with a tune using ectune-tuner. The car ran flawless. But ever since I started using ectune pro, I never got the car to run as good as with the tuner edition. Maybe its just me. The tuner edition is a lot more money, maybe that's why it might feel like it runs better.....
re
ya that is weird, maybe we can get Calvin to look at it. i hope we can, i want to get my car running right. i just started having another problem, well it was intermittent, i had a new mits eclipse gt trying me on my way to work this morning and i stomped his ass, then after words as i was crusing my car started leaning out, just crusing at about 3000 rpm and 6% throttle, but then i gave it a little more gas and it smothed out, then about 10 seconds later it did it again, and again, and again. it would shure be nice if i could record my logs to find out whats going on. someone please help out, i paid good money for this software, where is the 3 months support?
well first you dont need to be hot rodding your car when you dont have it tuned. It is likely that your IAT compensations need to be tuned. [email protected] send him an email
RE
its not leaning out at wot, and the ignition is fine, no detonation, it was the first time i have gotten on it, and it is limited at 6000 rpm. its kind of hard not to show Honda pride by stomping a mitsu's ass concitering that car is probably over 20k and he got beat by a Honda with maybe 5k in it. but anyways, do you have any ideas on why my data recording isn't playing back? i cant seem to get any awnsers.
