datalogger says it is recording but nothing
by the way
by the way i spent the last hour on the forum trying to find someone else having this problem, i found nothing even similar to my problem. what am i doing wrong?
screen shot
OK hears my screen shot. i figured it out
ect screen shot.JPG (239.76 KiB) Viewed 8969 times
RE
here is another log i recorded that isn't playing back. the file size on this one is 4.29mb, i recorded for about 20 minuets on my way home from work.
work dammit_13112009_1638_13112009_1712.elf
(4.29 MiB) Downloaded 381 times
you are going to hate this, but your log works for me
is your car boosted? What is your setup? after reviewing your log, it doesnt make any sense lol. I'm seeing 22psi boost at 3500rpm with only 70% throttle and a 13.5:1 AFR.
RE
wow thats weird. then why wont it play on mine? im running a sohc zc, turboxs t3 variant, 3inch down pipe,2.5 inch charge pipes, msd, nippon racing low comp pistons,guessing 8.5:1, eagle h-beams, block guard, arp head studs, stock head, everything fully balanced, dsm 450cc, NOS direct port fogger, walbro 225, b@m fpr(50psi@WOT). i think that is about it. so what do you think my problem is? should i try to reinstall ectune? will the licences i got for the first install still work? i dont know why the data is all out of wack like that, im only boosting 8 psi. im lost. PLEASE HELP
RE
im using the ostrich 2.0, and the extream hulog
Post by thething96 »
I've been having issues with ectune as well. The reason I asked if you had an ostrich is because to me it feels that some pro-ostrich ectune programs may be off. The very first time I used ectune, it was with a tune using ectune-tuner. The car ran flawless. But ever since I started using ectune pro, I never got the car to run as good as with the tuner edition. Maybe its just me. The tuner edition is a lot more money, maybe that's why it might feel like it runs better.....
re
ya that is weird, maybe we can get Calvin to look at it. i hope we can, i want to get my car running right. i just started having another problem, well it was intermittent, i had a new mits eclipse gt trying me on my way to work this morning and i stomped his ass, then after words as i was crusing my car started leaning out, just crusing at about 3000 rpm and 6% throttle, but then i gave it a little more gas and it smothed out, then about 10 seconds later it did it again, and again, and again. it would shure be nice if i could record my logs to find out whats going on. someone please help out, i paid good money for this software, where is the 3 months support?
well first you dont need to be hot rodding your car when you dont have it tuned. It is likely that your IAT compensations need to be tuned. [email protected] send him an email
RE
its not leaning out at wot, and the ignition is fine, no detonation, it was the first time i have gotten on it, and it is limited at 6000 rpm. its kind of hard not to show Honda pride by stomping a mitsu's ass concitering that car is probably over 20k and he got beat by a Honda with maybe 5k in it. but anyways, do you have any ideas on why my data recording isn't playing back? i cant seem to get any awnsers.
email calvin. You typically get a faster response through email since i believe it is connected to his phone. i dont believe it is a software issue though since it works for me.
Looking ectune does not have live graphing. i'll open your cal and log and post screenshots
everything is working. playback and graph review see attached
RE
i still isnt playing on my laptop, if i open the propertys of the log file it says there is somthing there but wont playback
