datalogger says it is recording but nothing
Tuner and PRO are the same bin/rom. so that is not the case at all. If your tuner used an old rom the fuel values maybe off, if ignition was tuned on the dyno you can use that without a problem and just tune FUEL. boost car right? 3k rpm 8 psi is nice... i'm used to extreme big turbo's:)
re
98vtec played it back on his too, but it wont play on mine
re
yes i am boosted, it is a turbo xs t3 variant. the turbo is maped to my motor so it starts spooling by 2500 and it reaches full boost by 3000 to 3500. but still why wont my log play back? when it says its playing all of the controls for play back are greyed out
here is my screen shot of it trying to playback the log file. notice the controls are greyed out
ect screen shot.JPG (239.76 KiB) Viewed 7195 times
RE
i even tried creating a new map and cal file to see if maybe the one im using is corrupt. still dont work
RE
calvin, can you remote connect to my laptop and help me out?
I would try a fresh remove/install of the whole program
re
ok, i did a fresh install and rebooted and everything is working now. thank you
didn't i post screenshots or was that an other user?
re
yes you posted some screen shots for me and my log files were working for you, but my old lap top was causing the problem. thank you calvin
np
