Syncing b16A1
				Pandor
Syncing b16A1
Hey all.    Just a little sync question.  I'm currently setting up a Euro B16a1 and need to sync the timing.    As far as I know the b16a1 has a 15° (+/- 2°) mark(s) on the pully (as opposed to a 16° mark on newer B-series).    So to correctly sync this, i'dd need to lock ectune to 15 deg using the sync tool, and then adjust the distributor so the pully lines up with the middle (15°) mark.    Does this seem about right?    Also, would a b16A1 run well with the p30 basemap (b16A2 stock map?). Or can anyone suggest a good ignition map for a a1 to start with?
						- utkuselamoglu
