B18C4 with B16B camshafts (max rev?)
- Wazzzup
I have an engine with the following spec:    * B18C4     * B16B camshafts    * B18C6 dual valvesprings    My question is what will the max rev limit be for this engine? (On the save side)    Stock rev limit B18C4: 8,100 rpm Max power: 7,600 rpm    Stock rev limit B16B : 9,000 rpm Max power: 8,200 rpm    Stock rev limit B18C6: 8,700 rpm Max power: 7,900 rpm
									EG H22A 1/4 mile 13.6 sec @ Drachten with eCtune
						springs dictate head rev potential, cams dictate which of those RPM are useful.    B18C4 = VTi  B16B (CTR) = 98+ JDM B18C (ITR)  and '00-01 USDM B18C5 cams  B18C6 = JDM B18C (ITR)    B16B (CTR) - 185hp@8200 & 118ft/lbs@7500  B18C (ITR) - 210hp@8100 & 130ft/lbs@7600       your springs should be safe for at least 8700 RPM. (more like 9000+, but being safe)   But you'll likely start droping power over 8200, I'd set the rev limiter at 8700 and shift at 8400.
						- Civic VTI-Turbo
