Lol, it was supposed to be fixed about a year ago now. I think its safe to assume that it is still the same.jpjackson wrote:why the heck would i do that?elevation wrote:hook up a bulb and CYAjpjackson wrote:i am back up and running, where is the update list for what was fixed? was the normally open and normally closed for the ebc fixed?there is no problem i was just curious if it was fixed or not, the normally open and normally closed selection for the boost solenoid is backwards and was suppose to be fixed this update. i am not going to hook up a bulb when i can just select the n/c and see if it works, my engine will handle 25psi and boost cut is set at 15 so no problem. i was just curious since there were no release notes with this update. so i guess the our normally closed solenoids are still normally open
oh well
update to be fixed by tonight!
