Bone stock 160K miles D16z6 BRMS ram horn manifold 60-1 bullseye dsm 450cc A smaller turbo would have made this a more usable power band. Late spooler, i wish we could have revved it more. Overall, great power and reliability. Wastegate 6 psi 10 psi Final
I have pretty much the same setup. I'd a ran it out to 8K and find out what rpm will result in most power under the curve. Then shift a little bit after that for less lag. You can rev the piss out of SOHC VTEC heads with a stock cam.
MADMAX wrote:You can rev the piss out of SOHC VTEC heads with a stock cam.
this is true... i used to have a all motor sohc...not built, but 40k shaved head intake header exhaust tune and i revved it to 9k on stock cam all day long
