ECT/IAT Corrections working for everyone?
Was messing around with my tune I went to adjust ECT corrections and notice my A/F ratio wouldn't change no matter what value I put in. Take a look
ECT Correction.JPG (199.02 KiB) Viewed 18839 times
Check the ECT.f and see if it shows it + or - fuel..
I've also notice this issue.
Yeah not working here, and a shift in temperature the other day caused my tune to be quite off because the software wasnt compensating...
do you see the correction there?
screenshot
screenshot
Did some testing today, everything worked for me except ECT fuel compensation. In the logs you can see everything work except for the ECT fuel comp. The part of the log from about 50 seconds - 1 min 45 seconds is when I was trying to get it to do anything, I tried random numbers from 1-90 and nothing changed.
iat ect test.elf
(565.4 KiB) Downloaded 524 times
tne after dyno 28 and 9s in march 2010.cal
(8.19 KiB) Downloaded 557 times
Thats kind of strange cause when you change the settings in the colder part of the table your cold start will react as you would expect.
calvin wrote:do you see the correction there?
Isn't that my point?
The corrections work fine. The issues is that stock honda code only updates ECT values every couple minutes it seems. so you won't see an instant change. If you keyy of then back on your values will update. I talked to calvin today about trying to shorten the update timer for ECT values so you guys will stop freakin out..
I use the corrections on every setup that flys outta here. I tweak start up fueling, correct for heat soak, compensate for outside temp changes, etc.
burgermass and i tested yesterday both seems to work fine. only ect used in the lookup updates slow.
When it used to work for me, it would show the change 5-10 seconds after inputting a value.
nope, hasn't changed.. I went all the way back to rom 46 and verified.
It hasn't changed for you, the corrections also haven't stopped working for you either but corrections don't work for me. I made some changes again to the corrections today, drove to a friends house got there and didn't log any correction. Turned the car on went home still didn't log any correction. Don't know what else I can say.
ok.. well calvin is going to revamp the ECT stuff so hopefully whatever bug is causing that to happen will be fixed.. We are aware the ECT has issues and were trying to get the solved.
