rev limiter problem
rev limiter problem
so the car runs perfectly fine everywhere, unless i hit rev limiter. ive got ign and fuel cut as rev limiter. and sometimes it seems like they dont engage. when it works it works great, will sit and bounce off limiter till i shift into third. but most of the time it will hit a stockish sounding limiter, bounce once maybe twice then lean protection will set. my limiter is set to 8200, ive seen on a log it made it to 8259, where duty cycle drops to 0. but neither fuel nor ign cut is set. has anyone else had this issue?
ok, not float, ran the limiter down to 7k and still does it. heres my cal file, and two logs, the second one( 52 pull.elf) is when it doesnt seem to be working. the first log(ends in 084918.elf) is a time that it did work, but still ended up hitting lean protection. anyone that can help me id GREATLY appreciate it. im new to the whole tuning thing so kinda learnin as i go full build is as follows: block: d16a (basically a y8 ) 75.5mm vitaras fjt rods balanced stock sleeves Head: d16y8 mild port and polish bisimoto cam crower springs/ret manley stk valves Aem adj cam gear(set to 0) Skunk2 IM H22 Throttle body Turbo: gt3276 love fab mani 3in turboback no cat no muffler tial wg/bov wg set at 1bar 2.5in ic piping huge fmic fuel: walboro 255 precision 1000's stock everything else ign: stock honda dizzy msd wires ngk 4554 plugs gapped at 26 Mgmt: ectune on chipped p05 from xenocron chipped for vtec Ostrich 1.0 LC-1 wideband old hulog (non extreme) im so confused, im hoping its somethin thats an easy fix
- eCtnew (add a bit).cal
- (8.19 KiB) Downloaded 385 times
- 52 pull.elf
- (61.29 KiB) Downloaded 373 times
- log_25042010_084918.elf
- (8.74 KiB) Downloaded 345 times
Yeah... with the low compression of vitaras, you probably don't have enough timing in ti so its breaking up. I run gaps that small pretty often on hondas with higher boost levels. If that clears up your issues, then you may just be too conservative with your tune, or need a stronger ignition setup. worth a shot
ok, so i do need to add some more timing, but did what you said, gapped em to 21 or so and still does it, just as bad. ive enclosed a pic of one of the plugs. its super blurry but you can see where the timing mark is. please any ideas would be fantastic
- photo.jpg (110.92 KiB) Viewed 5970 times
no.. not .021.. .016 .. Theres a big difference. And make sure when you gap it, you gap it good. You'll have to use a feeler gauge to gap that small, and make sure its flat between the ground strap and electrode and theres no play in it. I've seen many people gap plug to say .020 and they are really at like .028 cause they didn't hold the gapping medium straight lol. Post up your map and I'll take a look at it.
