rev limiter problem
dcletten
rev limiter problem
Post by dcletten »
so the car runs perfectly fine everywhere, unless i hit rev limiter. ive got ign and fuel cut as rev limiter. and sometimes it seems like they dont engage. when it works it works great, will sit and bounce off limiter till i shift into third. but most of the time it will hit a stockish sounding limiter, bounce once maybe twice then lean protection will set. my limiter is set to 8200, ive seen on a log it made it to 8259, where duty cycle drops to 0. but neither fuel nor ign cut is set. has anyone else had this issue?
92bluepreludesi
Post by 92bluepreludesi »
try using just one of them.
If your going that high on rpm, your probably seeing valve float unless the springs/cam are designed for that much rpm.... My .02c
dcletten
Post by dcletten »
Build: d16A 75.5mm vitaras fjt rods head: d16y8 crower springs/ret bisimoto cam mild port/polish gt32 tial wg/bov - wg set at 1bar ive got a good log ill try posting tomorrow. tired and headin to bed
dcletten
Post by dcletten »
ok, not float, ran the limiter down to 7k and still does it. heres my cal file, and two logs, the second one( 52 pull.elf) is when it doesnt seem to be working. the first log(ends in 084918.elf) is a time that it did work, but still ended up hitting lean protection. anyone that can help me id GREATLY appreciate it. im new to the whole tuning thing so kinda learnin as i go full build is as follows: block: d16a (basically a y8 ) 75.5mm vitaras fjt rods balanced stock sleeves Head: d16y8 mild port and polish bisimoto cam crower springs/ret manley stk valves Aem adj cam gear(set to 0) Skunk2 IM H22 Throttle body Turbo: gt3276 love fab mani 3in turboback no cat no muffler tial wg/bov wg set at 1bar 2.5in ic piping huge fmic fuel: walboro 255 precision 1000's stock everything else ign: stock honda dizzy msd wires ngk 4554 plugs gapped at 26 Mgmt: ectune on chipped p05 from xenocron chipped for vtec Ostrich 1.0 LC-1 wideband old hulog (non extreme) im so confused, im hoping its somethin thats an easy fix
eCtnew (add a bit).cal
(8.19 KiB) Downloaded 390 times
52 pull.elf
(61.29 KiB) Downloaded 378 times
log_25042010_084918.elf
(8.74 KiB) Downloaded 350 times
your probably having ignition breakup. try gapping your plugs down to somthing stupid like .016 and see if it clears up.
dcletten
Post by dcletten »
really? that low? i figured .026 was enough, but i do have a fresh set of plugs here so might as well try
Yeah... with the low compression of vitaras, you probably don't have enough timing in ti so its breaking up. I run gaps that small pretty often on hondas with higher boost levels. If that clears up your issues, then you may just be too conservative with your tune, or need a stronger ignition setup. worth a shot
dcletten
Post by dcletten »
ok, so i do need to add some more timing, but did what you said, gapped em to 21 or so and still does it, just as bad. ive enclosed a pic of one of the plugs. its super blurry but you can see where the timing mark is. please any ideas would be fantastic
no.. not .021.. .016 .. Theres a big difference. And make sure when you gap it, you gap it good. You'll have to use a feeler gauge to gap that small, and make sure its flat between the ground strap and electrode and theres no play in it. I've seen many people gap plug to say .020 and they are really at like .028 cause they didn't hold the gapping medium straight lol. Post up your map and I'll take a look at it.
dcletten
Post by dcletten »
should be up there, last of the three files i uploaded after the logs. ok my gapper went down to 20 so i hit 21 and went with it. ill dig out my feelers after work tonight and try it in a couple days (supposed to rain next two days here)
