I got a MIL Code 1, O2 sensor voltage error
				leed
Resurrecting an old post, since I see no solution.    I have the same issue. Running OL. Using Techedge wideband. When I connect the wideband output signal from the Techedge to the ECU I regularly get this error, mostly when letting off the throttle at high revs. If I connect the simulated narrowband output, the problem disappears. So its probably the voltage level that offends the ECU in some way.
									EG6 Supercharged/intercooled B19 @ 15psi
