Sporadic A/c
- ckretvix
Sporadic A/c
Just installed a \"new\" (different) compressor as my old one had a hole in it (my fault) as well as the drier and refilled the system. Everything was great until today. The A/c will kick on and off depending on the revs. If Im idling it will stay on and cycle normally but if you start to rev the engine the a/c will kick off and then kick back on sporadically. this happens regardless of load. Pressure readings when the a/c on from the low side port is where it should be. It may be the latest version of ectune as I havent hooked up my computer to the car in a while until today and symptoms started afterwards. I know Ac cut is turned off
Heres a log file of just cruising down my road at constant speed and the a/c just kicking on and off every 5 seconds.
- actroubls2.elf
- (336.17 KiB) Downloaded 270 times
- Chris_tune.cal
- (8.19 KiB) Downloaded 246 times
