Fuel cut problems
Wazzzup
Fuel cut problems
Post by Wazzzup »
The problem: When letting go of the throttle with high rpm fuel cut kicks in and suddenly there are spikes in the fuel cut. I have made a new cal today and log. Already tested a couple off different values. Changing of the fuelcet settings made no or almost no difference.
B18C4_08102010.cal
(8.19 KiB) Downloaded 457 times
B18C4_08102010.elf
(6.25 MiB) Downloaded 441 times
EG H22A 1/4 mile 13.6 sec @ Drachten with eCtune
fcut delay setting is my guess; stock is 600ms I believe
Wazzzup
Post by Wazzzup »
JaredKaragen wrote:fcut delay setting is my guess; stock is 600ms I believe
Yes, 600ms is stock but I modified some values and now it's beter than the stock values. But it still isn't what it should be.
