Boost Cut and EBC Problem
Hey guys Can someone take a look at my map and datalogs please and tell me where i'm going wrong. I keep hitting boost cut for some strange reason. Also my EBC seems to be work backwards and i'm positive i've got it setup properly (100% DC = WG pressure 0%DC = Full boost) . Is the way i have the ebc setup in the pictures below correct ? Thank you all for your time Richard
- Rich.cal
- (8.19 KiB) Downloaded 148 times
- Rich 7psi.elf
- (186.99 KiB) Downloaded 138 times
- Rich 9psi boost cut.elf
- (89.63 KiB) Downloaded 150 times
- 4thgenhtch
Hey I`m richard too Yes your vacuum is setup right, I was having the same issues theirs a glitch in the program, switch NO to NC or vice versa in the software... and go from there map out your duty cycles, for your look up tables and then you can fill out your boost by gear tables from that... http://forum.ectune.com/viewtopic.php?t=2871
<img></a>
- 4thgenhtch
