Engine: B16b (1820cc, 81.5x87.2mm) Wiseco 12.5 cr race prep pistons Manley H beam rods ACL race bearings B18c type R oil pump B18c type R water pump B18c type R ported cylinder head with full radius valve job Supertech nitrided valves, valvesprings and titanium retainers Jun type 3 camshafts with Skunk2 pro camgears RMF narrow header 2.5�-2.75� test pipe with flex pipe Kakimotor R 2.75� catback Edelbrock Performer X intake manifold (ported) Professional products 76-68mm throttle body 3� intake with BPI flow stack, filter and airbox RC 370cc injectors Walbro 255lph fuel pump B18c type R ignition rotor NGK Iridium IX BKR7EIX-11 spark plugs NGK spark plug wires Gates Racing timing belt Gates Racing low temp thermostat Godspeed ITR DC2 full size radiator with 12\" slim fan Spoon radiator cap Custom breather tank system Avid Racing polyurethane engine mounts Racimex oil cooler Torco SR5 5w50 motor oil and MPM G12 coolantB16B 1.8ltr Jun3 250 CHP - 222WHP
- Garrett
I always love JUN3
- utkuselamoglu
- Garrett
14:1 WOT, is a little bit lean
I got it on my laptop, give me a few days and I will post the .calFreshDA9 wrote:very nice. im working on a Hi compression big cam B16 and need some help with a good start in the timing map. would you mind posting some screen shots of the timing table.
Thank you. im mainly interested in idle ignition for big cam cars as of right now. i looked threw a lot of cals and noticed most sit at stock 16.5 degrees at idle. my mentor said
i ask this because i have this b16 in high 40's at idle and i feel im doing something wrong, i kept adding timing and it kept getting lower in KPA. it does have crower stage 2 and 3/4 cams and valve train. My biggest issue is timing as i feel i still dont understand other then what the dyno can tell me after pulls. I do read plugs but not as often as i really should.A motor can only pull so much vac depending on the cam. You keep adding timing until you stop seeing an increase in vac. No point in adding more timing if the vac does not change.
Idle ign is like stock at 16,5 degrees. runs fine.FreshDA9 wrote:Thank you. im mainly interested in idle ignition for big cam cars as of right now. i looked threw a lot of cals and noticed most sit at stock 16.5 degrees at idle. my mentor saidi ask this because i have this b16 in high 40's at idle and i feel im doing something wrong, i kept adding timing and it kept getting lower in KPA. it does have crower stage 2 and 3/4 cams and valve train. My biggest issue is timing as i feel i still dont understand other then what the dyno can tell me after pulls. I do read plugs but not as often as i really should.A motor can only pull so much vac depending on the cam. You keep adding timing until you stop seeing an increase in vac. No point in adding more timing if the vac does not change.
.cal from this monster. Enjoy!
- Rick-ect.0065-rev10kortepijp.cal
- (8.19 KiB) Downloaded 4359 times
Just to be safe. With this kind of engine, I always activate the 11th column to be sure that if it reads from this 11th column it reads the right values. I thought Calvin made something to avoid wrong readings but I just want to be sure.
A whopping 222 WHP!
