Piston/Rod D16Z6, Mike Belben Head port - 300 whp @ 13 psi
I couldn't believe it when I saw the graph...this is the FIRST pull at WOT, 2nd pull with some minor AFR changes netted 246.7. Unfortunately, the original design of this motor wasnt to lat very long and the head parts were skimped on. Stock springs, retainers, valves really dont like revving to 8k
About 6 or so pulls in, the car started acting strange...sounded funny but I couldnt pin point what was happening...did a couple more pulls and power was dropping to about 232, did a compression test and Cyl 1 had ZERO comp...my stomach dropped and I had my employee pulled the VC. Its still preliminary but it looks like one of the \"locks\" (?) failed and one valve is hung open. I have to do further investigation but hopefully the valve isnt bent and there is no internal damage as it does not look like the valve dropped far at all. Still amazing the car was making that much on the final couple of pulls. I am going to try and get the owner to let me pull the head and upgrade the valvetrain. Full setup on the motor: Stock Sleeve (.020 over) JE 9:1 Piston and Tuner Toys Rods, ACL Bearings Mike Belben D16Z6 ported head and valve job Supertech valves, springs, retainers ZEX 59300 Cam Ebay T3/T4 Turbo Kit...60 trim perhaps? 13 PSI, Ebay Wastegate Precision 525cc High Imp Injectors Custom 2.5\" Downpipe (Xeno-Fabbed) Taking this thing to 300 reliably should be easy once things get fixed.
- D16z6-MikeBelbenHead.jpg (133.65 KiB) Viewed 10978 times
boostedsol
EMAIL...and believe me, the power is in the head work here...not the tuner. I can only do with what is given to me. I have an H22 head and an ITR head at Belben's right now...cant friggen WAIT until they come back nowboostedsol wrote:nice work, i cant wait to get my car done, and hopfully have you tune it. I have a couple questions for you actually what would be a better way to contact you, phone? or email?
boostedsol
Joey Misanthropy
After I called him and told him...he said, "thats it, im going up another $100 on each head" Joey, we need a chat...call me this week or text me when you have a free moment.Joey Misanthropy wrote:This gives me a warm fuzzy. I always said Mike Belben was a hardcore motherfucker.
- yc underground
Keep up the good work Chris, hope you are enjoying your new dyno.
Got the head back and retuned...nice!
- D16z6-MikeBelbenHead-300whp.jpg (140.65 KiB) Viewed 10880 times
- Boosted K20
mike_belben
