Trace and AFR logging Update
I change the trace method of single and quad cell trace. The afr values are also weight now when storing them. I do these calculation based on the actual fraction the ecu is using at that time. Please see screenshots
- Most Active cell being used in quad cell trace
- trace.quad.new.jpg (17.21 KiB) Viewed 9831 times
- Most active cell is now the single cell being showed.
- trace.signle.new.jpg (17.52 KiB) Viewed 9832 times
- yc underground
Nice
the 4 cell smart track should i keep it to 4 cells or should i select the primary cell that is being used out of the 4 cells? Advice please
what I find odd about this new thing, is that if you see in your images the lower right cell is green, but the little indicators that are supposed to show what cells the ECU is reading from is more towrds the top left.. So, whats the purpose of highlighting the single cell yellow if thats not where the ECU is reading from..
there are 2 indicators 1 for rpm and 1 for map. I disabled them now. They caused i think the lock ups. But i still have to test that
