Stock GSR w 12.5:1 pistons E85 N/A
I wouldnt imagine netting more power exactly on E85 with an NA motor... That thing needs bigger cams...DESPARATELY!!!Gaskleppie wrote:What are the big differences except the timing? What AF gave the best power?
- Boosted K20
It wasn't any more difficult to tune than gasoline.. It took alot more fuel, but the timing was suprisingly simular to gasoline.. I ended up with a few degrees more timing than on gasonline, but nothing crazy.. Having higher octane has nothing to do with making more power. Just means its more resistant to knock. its does need some bigger cams, but the customer just wanted a daily driver that was clean burning, the higher compression was for better fuel efficiency. E85 is not very fuel efficient on lower compressions. It made best power in the 13.5 A/F range. It ran at lean part throttle A/Fs 15:1-16:1 without knock, but I went ahead and richened it up to about 14.0 just to be on the safe side. I'm interested to see how the fuel effecieny is affected by runing really lean part throttle A/F, since we can do it with no knock, but I rather test this on my own motor and not a customers ; P .. Oh yeah and when I pulled the plugs to check them after we were done, they still looked brand new except for color change on the ground strap.. Form what I could see, I could probably eat of the pistons they were still so clean..
It was a bone stock b16 head. I did some calculations and that throttle body maxes out around 180 anyway. I almost have the part throttle tuned out 100%. One other thing. The iat corrections needed tweaking would start running more rich as it would get warm. With the e85 it wanted even less fuel as the temp goes up. I am getting around 30-31 mpg on it right now and that's with a part throttle at 14.6 anyway I am happy with the result. As u know I just wanted a motor to be able to burn e85 not build an n/a race car. BOOST is the only way to go with a honda....
I bought a aem wideband saterday when we were at the dyno so I can have one installed in the car. I plan on running it closed loop with the input just have to make a nice mount for it this week. I did check the egt yesterday just playing around and it maxed at 780 F and that was a very long pull in 4th gear. I was curious too since I knew it should make the egt cooler. Btw I have rc750cc right now and wot the duty cycle is only 44%
Good luck with that, I think both the Zeitronix and AEM have a non linear output which could make for nice frustration while trying to setup closed loop wideband feedback.redshade5 wrote:I bought a aem wideband saterday when we were at the dyno so I can have one installed in the car. I plan on running it closed loop with the input
Perhaps that's why I have heard people complaining about the scaling offset changing threw the rpm range. I haven't tried it, but I am sure you know better than I do.I just generally assume its user error more than hardware error. I just didn't want to stick my plm in the car for fear someone would steal it. I guess I will just test the closed loop wideband with the plm to see how well it works and then just run open loop. Do you recommend any other widebands?
I'm dring with an Zeitronix in closed loop with no problems. Ask Gaskleppie since he tuned my car...xenocron wrote:Good luck with that, I think both the Zeitronix and AEM have a non linear output which could make for nice frustration while trying to setup closed loop wideband feedback.redshade5 wrote:I bought a aem wideband saterday when we were at the dyno so I can have one installed in the car. I plan on running it closed loop with the input
