Sensors pane won't hold values and error...
My first Error: It has to do with the Sensors pane, and changing the ranged values: The values under BOOST do not stay... I was going through the \"Sensor Setup pane\" and I changed a handfull of values so that my sensors (IAT and ECT mainly) were in the correct ranges and not showing up as red on my logger pane. One thing to add: is for all the values in that pane to add ranges and numbers info for what formats each field can use (in the case of ECT, a whole number 0-300, etc) and if you switch from Celcius to Ferenheit, then these fields should automatically convert as well when switching =) After thinking about it, it might be related to the use of non-interger type numbers, and having a decimal value. Pic of eror: http://i26.photobucket.com/albums/c115/ ... CTune5.jpg ***Exact Steps to reproduce:*** Start a new rom. click next, click next, click finish. options menu->sensors setup, click on \"Boost\", Enter Min value of 7.0, and max of 7.5 click on the PA settings, click back on boost and min and max are reset to zero. ***bug #1*** still in the boost setting, enter 7.5 min and 10 max click close Error dialog pops up. ***Bug #2*** ***Exact Steps to reproduce:*** But I think you can do this with any rom, because I created a new one to reproduce it; just to try. Here is the Error given in windows (Vista Home Basic): See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at eCtune.frmSensorSetup.–˜‰Œ�‘†—�() at eCtune.frmSensorSetup.–�˜ŽŠ’•’š(Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.0 Win32 Version: 0.0.2.0 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.0 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.0507 _________________
please don't post double. If you read your previous post. You would see the bug is already fixed in the next release
