D16Y7 - Vitara Setup - 23.5 psi - 280 whp
Setup is as follows: Stock D16Y7 Head D15B7 Block, 200k miles plus...slight hone Vitaras and Eagle rods RX7 550cc Injectors Stock IM Small Intercooler Wacky charge piping Side exit exhaust GM 3 bar This car was FUN to tune
- Joe-Holset.jpg (136.01 KiB) Viewed 18515 times
No typo..it had Eagles Holset HC1, thats all I know. built in traction control with the slow spool
Def post it up
This car/driver went 12.15 with this car and his old setup (just barely 200 whp) so I cant wait to see what he does with this
the *NEW* -15.3cc gives a compression of 7.45:1 with the z6 head and 7.11:1 with the y7 head if everything in the calculator is correct. im not sure about y7's combustion chamber volume. some say its same as the z6(34.6cc) others say same as the y8(32.8cc) which i doubt. this compression calculator says it the same as the a6/b7(38cc).
http://www.honda-tech.com/zerothread?id ... 53#3943653 calculator: http://web.archive.org/web/200703050144 ... eries.html
blundar
I did a Y8T with a peakboost kit on it that made 310ish on 20something pounds with a 50trim t3t04e. I'm having some issues with vtec transition on the street (was perfect on the dyno? go figure). I'll try to post up the graph in the new years after I get back there.
Thats where it hit peak boost
car went 12.2-12.3's all day trapping 112-113mph with 282whp on 18psi. never got a clean run after getting it dyno tuned.
