Possible Datalogging Issue
Not sure if it was a bug or what since I didn't have time to try and replicate the issue cause of the battery dying on my laptop but, I thought I would post anyways and see if someone else wants to try it out and see if it happens to them. Anyways, I was out for a couple hours yesterday and was datalogging most of the time, but not recording. After a little bit I hit the record button on the toolbar and everything was working fine. After about 10 minutes I noticed the battery dying and hit the stop record button and then noticed the map trace stopped. I then tuned off the datalogger, started it again and the map trace still didn't work I was going to close out the program and start everything over but that's where my battery life became critical and I had to shut down. Well that's it, just thought that I would post and see if anyone is getting out soon, could try it and see what happens as I won't be able to get back out for a few days due to rain. Thanks !
welll guys i would test again. If it's a bug and i have the steps i can do something. I tuned yesterday for a total of 4 hours on 2 different laptops. No bugs reply
Supposed to get a break in the weather tomorrow so if it's good outside when I get home from work I will head out for a bit and see if it happens again. Think Adam might be right though, might have just been freaked cause of the low voltage of my laptop at the time. I just thought I would post it up and see if anyone was gonna go out tuning they could try it and report back if they had any issues.
most laptops disable USB/serial ports when the power gets critically low. This has hurt me many times in my field service position. I don't think it was an eCtune flaw just a battery conservation condition. Most people use an inverter when tuning as their laptops don't give them 'hours' of runtime, especially with processor intensive operations. I wouldn't recommend doing it just because it will hit you when you need it not to the most.
I played with this on my car a little more this morning, It seem to only highight the square that the engine is running in when I open the window. For instance if I switch from the graph to the table while I am at 2000 rm at 1200mbar it will stay there and not move, After that will open the graph and the chase will work on the graph, then I will rev to 3000rpm and close the graph to view that tables and it will stick on the 3000 rpm and not move no matter what I do with the car. I can open a data log and it will work correctly, I just like to view real time while I am trying to tune. Wierd?
