14 psi:
19 psi:
Car's neat as a pin, I'll make sure to get copies of it's pictures before updating.Moderator: Gaskleppie
14 psi:
19 psi:
~14.5 psi:
18 psi:
20-21 psi:
What's the easiest way to put it in correct time? Do the math based on how much the setup has been decked/milled, or something out?Joey Misanthropy wrote:It really takes a second to catch on with the D16... low mileage stock block that was barely milled or decked during the build translates into the the engine is 2-4 degrees out of time. Every D-series needs a cam gear, and to be put into correct time, before the tune starts.
which one would you recommend ?Joey Misanthropy wrote:It really takes a second to catch on with the D16... low mileage stock block that was barely milled or decked during the build translates into the the engine is 2-4 degrees out of time. Every D-series needs a cam gear, and to be put into correct time, before the tune starts.
