Zex/Comp are the exact same company, you even get comp boxes when you buy Zex stuff, but you get Zex stickers inside. I believe this car however is using a Crower cam, not a Comp.Adam Hopkins wrote:I was under the impression that the zex was the same exact cam as the comp cam. I you look at both companies addresses then you will notice it is the same street in memphis, Also if you go to comps web site they have links to zex's website. It should be the same cam, just marketed differently.
