Datalogging bug(s) 0.2.0r8
Which version is on the 'Force update' of the logger right now?
2.0r7 I believe
these bugs are fixed in newer versions 0.0.2.1r1>
Re: Datalogging bug(s) 0.2.0r8
blundar wrote:Bug #2: 1. Key on 2. Datalog.. Connect (works fine) 3. Key off 4. Datalogging still says connected, but no data comes. 5. Key on 6. Dataloggins still says connected, but no data comes. The bug appears to be the datalogging connection getting stuck. If you click Datalog..Disconnect then Datalog.connect, it will start working again.
Having this exact problem with the Force Update version r7. If you click test in eCtune Settings menu an error message apears (see attached pic). After that Connection works normal again. Shutting down and restarting eCtune also does the trick.
Error
Error
fixed in 0.0.2.1> which will be released really soon
I key on-off all the time and just elave datalogging connected and I've never head the lockup issues.. I'm using USB with the hondalog.
same here
Using Hondalog also but since the force-update having this problem, not before...
very very weird what version were u using before r7?
Yep used r7 and didn't have any problems...
r7 is still r7 nothing change only exp. date
z31
Post by z31 »
When using r7 I used to always key-on/off. I usually stop for gas and just leave it running (the program not the car), it would always just reconnect automatically, no problems at all.
It did, before te update!
z31
Post by z31 »
Actually, what I meant to say was I've never had that problem with any of the revisions. I was at work when I made that first post, just thought I'd clarify. :oops:
well code wise nothing at all change just the exp date. So i would say laptop/related. Try a clean install
