Played around with it some more; Ok, The lower the RPM, the less retard it wants; sounds correct; Tested by way of doing low and higher RPM FTL settings, with different amounts of fixed values and getting similar sounding results. The FTL resume needs to be higher the higher the RPM's go; so if lower RPM lets say 2K, your going to want a 5-25RPM resume; 4,000: 75-200RPM (didn't go higher) Heres something interesting: When I would get it dialed in to emit a huge pop down low, you would get one good pop, and a bunch of smaller ones when the fuel/ign was optimal for that RPM. But at higher RPM (4K) with a 108RPM resume, I get one HUGE pop, and it will pop small, or rev waaaay smoother and make more of a hissing sound; this could be 2 things in my opinion... too much retard, fuel or more FTL resume added.... need to expirament more. *** I think to control the 2-step better, there should be a slope for fuel Vs. RPM, this would give a better result IMHO. Maybe low and high RPM values (user definable) and low and high fuel values. So, end result for me tonight: I think the one HUGE pop will be waaaaay more than enough to get her up to 14+PSI; but I do not have a turbo on right now, so I am just using my \"Soon to be vitara'd motor\" as a guinea pig. Good news: I took video, deafened my friend, felt a huge compression wave each huge pop (flamage) and it kinda blew a shitload of crap everywhere, and killed a bunch of a small plant I was parked in front of; sent plant into the parking lot =P Problem: I have no way right now to download the video off the FireWire, cause this laptop doesn't have it... and my home PC's power supply fried. Soon... I promise... like 1.5Ft flames! (with OEM header, catalytic converter, and Anyways, here's the eCtune settings pics, and as soon as I can get a machine with 1394 to download the video, it's all goin out to you guys =) It turns some heads!!!
