Lean Protection window...
In the parameters under lean protection, put a single ascii charachter in one of the fields; I did it accidentally in: Lean Protection 1 Maximum AFR V= 'z' (tried to undo change with CTRL+z) or for that matter, leave it blank and click another field. It will crash. I will provide program error if needed, but I am confident your copy will do this to you. 0.0.2.1r2 AntiLag test version
i'll look into you mean validation of entered text right
exactly; it seems to error, then click continue on the error popup and you see the liitle red '!' pop up afterwards next to the cell =) Expect to see alot of these types of errors for me; I am normally good at finding them without trying =D
find all.. :)
fixed
if you add a text char to the \"above load\" field: so it reads: 3.96z, it will crash This happens in lean protection 1&2. Also the duration fields for 1 & 2. This weekend, I will sit down and test every parameters field for blank, text, integer, and char* type inputs so that all of em get knocked at once. But; good thing is it seems they are mostly on the new panes added recently.
i'll fix that.. thanks
i'll check as much as i can tomorrow and update you
