Show your wideband!
Show your wideband!
This is my Innovate wideband I use for street and dyno tuning. Who has also a nice setup like this? I dont use the gray cable anymore. That was the old connection for the analog connection to the ecu. But I leave it for the button and checklight.
- widebandsetup1.jpg (723.71 KiB) Viewed 91119 times
- widebandsetup2.jpg (458.18 KiB) Viewed 91119 times
A while ago I made the 1\" pipe a bit longer. (see the welding) After that even idle is no problem anymore. You just have to wait a few seconds before the gases reaches the sensor. On throttle, the gases are traveling so fast you almost have no delay. I can mount this setup in 1 minute without heavy tools or lifting the car. It works like a dream. Perfect for street tuning.
90% of the time I use the sensor in either the original bung, or have the customer install a seperate bung before tuning. I want those fast reaction times and precision. I still have my original 6066 wideband sensor which is now 3 years old or so. The thread does not look pretty, but it still works. I´ll do an accuracy test some time and see if it drifted somehow. Wideband controller is built into the ECU. Now converted to the more recent LSU 4.9 . /Allan
- Wideband built in
- Tuning%20ECU.jpg (52.86 KiB) Viewed 91062 times
1 AFR? So 13 is measured like 14??? Whow! You must be measuring the wrong way. I have checked several times and with this setup I have no difference at all. The key point is to make the pipe long enough so it can not measure clean air. I have 1 permanent installed Innovate in my own car, and I have 1 for tuning like on the pictures above. So its very easy to compare them.Why on almost all cars i have noticed a 1AFR difference if i mount the sensor on the exhaust tip, than mounting it on the stock position either with the catalyst on or with a test pipe.
- Boosted K20
Nice! I had a similar connection on my ecu. It gave the wideband 12V power and the 0-5V signal. But after this mod with the switch to change the lambda input I got a huge AF offset. Now I only use the serial connection. Works perfect!
- Tuning-ecu.JPG (154.21 KiB) Viewed 90952 times
- Tuning-wideband1.JPG (107.59 KiB) Viewed 90954 times
- Tuning-wideband3.JPG (99.19 KiB) Viewed 90954 times
[/img]
