Possible random code 10 or code 1?
- mtber
I have had two customers contact me telling me that they had a random code that is a single flashing code. My guess is a code 10 as they said it was kind of a long flash.... Both customers are on v 0.0.2.0 using a .46 base. Anyone else see this issue ? VE/O2 Disabled on both cars.... Thank You, John Vega
Phearable.net - Toll Free: 1-888-236-9831 Chipped Ecus / Precision Injectors / Walbro Fuel Pumps / AEM Widebands / Conversion Harnesses Authorized Dealer for: Hondata, eCtune, Neptune, AEM, Crome & more.
the stock option? There is stock closeloop+ve disable and 2 seperate one Closeloop disable VE disable. Try using the first option only
- mtber
Will this fix the issue or is it just a guess ?calvin wrote:the stock option? There is stock closeloop+ve disable and 2 seperate one Closeloop disable VE disable. Try using the first option only
- mtber
Using the latest devel version with .54 bin I did not click \"closeloop+ve disable(stock)\" and I have a customer reporting a random code 10. Is this bug still around ? I assumed the bug was resolved so I didn't select disable \"closeloop+ve disable(stock)\"
- mtber
I doubt it as the car never had this issue while tuning on the ostrich/laptop. I had one other customer with this issue...Bindegal wrote:I have never heard of this from any of the cars I eCtuned... Admittedly, most of them leave my hands with closed loop carefully tuned and enabled. Could it not be an intermittant IAT sensor problem? (CEL=10) /Allan
ectune does nothing/modding code near IAT/IAT error. If it's code 10 it's a realy code then or the guy can't test/read codes. i never had the code one some of u are reporting.
btw i never fixed any bug regarding o2 code. I just say try the other methode. that is stock the closeloop disable only is a custom routine based on the tps disable of closeloop
- mtber
The issue did not occur for me on my p28 with the romulator. I disabled \"closeloop+ve disable(stock)\" and re-checked the tune & reburned the chip. The random code 10 went away thus far.
