Just minor things
MADMAX
Just minor things
Post by MADMAX »
1) When viewing the Target AFR (F10), the three interpolate functions as well as the smooth function do not change the Target AFR table. They will change the main fuel table. Increase, Decrease, or Adjust Selection functions work properly. 2) One feature that I think should be added is when you have more than one cell selected and you punch in a number, it should change all selected cells. I know you can use Adjust Selction, but a lot of of other tuning programs (non-honda) use this and it is much easier than hitting CTRL+J every time. 3) The shortcut info CTRL+J should be added to the right click menu on the tables. 4) All possible data functions (interpolate, increase, etc) should be added to the EDIT menu up top. 5) Group the data functions into one toolbar. Right now, the datalogging functions are grouped with them ie Map trials, etc. Also, add Adjust Selection to the toolbar. 6) The first four items in the Options menu (Follow VTEC, Follow Secondary Maps, Smart Track, and Map Trace Trails should be moved to the Datalog menu. It just makes more sense to me to have them there. Program is great Calvin and to everyone that is helping. Keep up the good work.
Re: Just minor things
MADMAX wrote:1) When viewing the Target AFR (F10), the three interpolate functions as well as the smooth function do not change the Target AFR table. They will change the main fuel table. Increase, Decrease, or Adjust Selection functions work properly. 2) One feature that I think should be added is when you have more than one cell selected and you punch in a number, it should change all selected cells. I know you can use Adjust Selction, but a lot of of other tuning programs (non-honda) use this and it is much easier than hitting CTRL+J every time. 3) The shortcut info CTRL+J should be added to the right click menu on the tables. 4) All possible data functions (interpolate, increase, etc) should be added to the EDIT menu up top. 5) Group the data functions into one toolbar. Right now, the datalogging functions are grouped with them ie Map trials, etc. Also, add Adjust Selection to the toolbar. 6) The first four items in the Options menu (Follow VTEC, Follow Secondary Maps, Smart Track, and Map Trace Trails should be moved to the Datalog menu. It just makes more sense to me to have them there. Program is great Calvin and to everyone that is helping. Keep up the good work.
1 this is how it should work 2 Have to look into it 3 Will do 4 those are table function only. I'll see 5 Make a screenshot and explain 6 I'll see Let other people give opinion
1) Calvin, Can you disable the interpolate and smoothing buttons when AF Target, AF Reading or Est. Fuel Change is selected. And the VE Tables (if that is going to stay in the app) 5) Adding ajust selection to the toolbar is a good idea -- I'll make up the gfx for this is you want Other than that I think most of the other stuff is fine where it is.
nate wrote:1) Calvin, Can you disable the interpolate and smoothing buttons when AF Target, AF Reading or Est. Fuel Change is selected. And the VE Tables (if that is going to stay in the app) 5) Adding ajust selection to the toolbar is a good idea -- I'll make up the gfx for this is you want Other than that I think most of the other stuff is fine where it is.
Send the GFX then
MADMAX
Post by MADMAX »
The interpolate functions should apply to the Target AFR table. It makes more sense to have that. I like Nate's idea of having them grayed out when viewing logs though. It just gives the user access to functions that are already there. Also, I attached a screenshot of 5)
eCtune 1.JPG (117.89 KiB) Viewed 4774 times
calvin wrote:Send the GFX then
done
just selection during logging/recording is already on the toolbar before \"+\" What do you mean CTRL-J add to toolbar? I'll add ctrl-J to that bar before adjust selection and move the seperator to the left. I don't want 100 different toolbar
I think he means add \"Control-J\" to the right click contex menu
MADMAX
Post by MADMAX »
nate wrote:I think he means add "Control-J" to the right click contex menu
Yes
