Catch Can/Breather set-up
What does everyone here do for crankcase ventilation? I was thinking about the endyn set-up but then started talking to someone about a vacuum set-up that I don't think will work, so I thought I would post maybe get your ideas, thoughts and maybe see some pics of your set-ups. Thanks !
i only vent my block as of right now, ill get to the head eventually. i use the OEM fittings on the back of it, with all of the stock stuff removed. no pics but there is a ton of them on h-t. i also have a self made can that i made out of the charcoal canister. it fits in its location and looks \"stock\" but the drain back is almost nonexistent. no idea how well it works but i do have to add oil every once in a while.
Here a link from HT http://www.honda-tech.com/zerothread/1199935
rschoener
We use two Endyn Catch Cans also right now. The one from the block drains back to the block. The one from the head needs to be checked from time to time. We have not had much oil build up in them. I will be trying a Check valve setup to the exhaust to help evacuate or create a vacuum in the block catch can. Many dragsters run a line with a valve from the header to the valve covers. I have heard roomers of this freeing up some extra HP.
- shop_pics_074_220.jpg (80.31 KiB) Viewed 10136 times
This is what I want to do also but not to the valve covers. Basically I want to use whats there and then just vent into the exhaust under boost but I need to find check valves that will work at high temps.rschoener wrote:I will be trying a Check valve setup to the exhaust to help evacuate or create a vacuum in the block catch can. Many dragsters run a line with a valve from the header to the valve covers. I have heard roomers of this freeing up some extra HP.
I don't think it would be hard to fashion some sort of metallic check valve if you have a lathe on hand =) or use an GPO to activate some sort of high-temp solenoid to the exhaust when x-psi hits. =) These inputs/outputs are becoming very handy!
I'm going to change it shortly, setup will be the same but more bling factor
