huge issues today at the track. couldnt even get one clean run in.
here is my setup; stock b16 block/head AEBS intake mani cast exhaust mani [i know, i know] holset he351cw turbo [info on the turbo
http://www.turbododge.com/forums/f4/f19 ... eware.html ebay 38mm WG w/ 7psi spring [working condition] 3\" downpipe/exhaust it ends right past the linkage i did a real rough tune after all the problems i had with the 1k injectors to be ready for the track day today. i noticed the boost was creeping up to 8.5 and sometimes 9psi AT THE MOST. it didnt bother me much so i left it as is. today on the way to the track i installed my MBC that i also know that it works flawlessly. it held 20psi last year rock solid. but today i couldnt get it to hold ANYTHING ! i was looking to run 12psi at the track but on the way there it kept hitting boost cut which was set at 13.75psi. i tried everything that i could think of but nothing would get me even close to my 12psi goal. i even took everything out of the WG and it still overboosted.
only thing that got me somewhat close to 12psi was loosening the screw in the MBC [no spring or ball inside] as much as i could with out it falling out and by doing so it read between 12-13psi in 3/4 gear. when i came to the track and looked over some of those logs i noticed i was only getting between 90-94% throttle. i corrected that and it then read 99-101%. i did a run hitting boost cut left and right. second run i took the MBC off and it STILL kept overboosting
i then raised the boost cut to 16psi and sure as shit it still hit it. i took the WG apart and everything seemed fine, no holes, loose screws or anything out of the ordinary. WG signal is coming right of off the nipple on the comp housing that the stock internal WG uses. talked to Jake Montgomery [current fastest 4cylinder in the NW] and he said it might be the size of the turbo combined with the not so good exhaust manifold and relatively low boost. your thoughts opinions ? oh, and sorry for the novel.
