did some tuning today and everything worked like it should. now im looking at some of the logs and i tried to add final ignition to the graph and thats when eCtune crashed. i tried to see if an older version would work but they are \"locked.\" everything is up to date on my laptop so idk whats going on. everything works fine[kind of slower then usual]but as soon as you hit the graph icon it crashes. it doesnt matter what map or log. it actually does it on startup when there is no map at all. and here is a screen shot;
more screen shots.. this is a new one i get when trying to open the graph w/o any log files and this one popped up when i was exiting out of the one above.
Just a heads up: Close eCtune, then load it writing step by step, try to get it to happen again... You said you were trying to increase the timing, so how exactly? did you just select a section on the graph and using the increase selection button? That's definately a rooted bug. If you post up specifics and your .cal and log I can give it a go. Man.. it seems your good at running into those odd graph bugs
this is the simples of them all.. start eCtune>click graph>error msg it doesnt need to have any cal's or logs open. no, i was trying to add final ignition to the graph so i can see how it looked. yeah, me and this graph thing dont like each other much. lol
zex: Lets get how this happened straight; 1) Was the graph ever working for you? 2) It sounds like the graphs stopped working after you tried to add final ignition to the graph correct? If both of these are true, it sounds like something in the graph template file didnt get written correctly. Let's see what Calvin thinks...
downlaod in ectune\\setttings and extract and replace files
(4.17 KiB) Downloaded 281 times
I think the actual question is what exactly did you do so we can fix the problem so it doesn't happen again I'm going to play around and try to reproduce
