Timing question; Ign Sync Lock
I was wondering, does the service connector still disable ign correction ? If not, I can somebody tune with eCtune adjust his dizzy ?
remember i was talking to burgermass yesterdat about it. Wat SCC does is disable only IDLE ign correction. stock ecu idle region 16deg. So if you now set idle to 20 DEG you have a problem.. I'm current coding something for that... SCC will disable IDLE correction but dizzy will be at 20. I'll make an option u can enable in eCtune at replaced the SCC function and just lock the IGN to 16 deg
Ok.. Update... E.g. if you put 20 deg at idle and use stock dizzy sync the timing will be 20 deg. SCC only disable ign idle correction. I did some changes KOEO TPS error checking is always enable. You can select any input for SCC routine. When you enable SCC the ignition will lock to 16.5(or custom value) the same value you use with ign sync tool.
ign Sync.JPG (24.37 KiB) Viewed 3450 times
I like the Ignition lock feature here than in the test window. Granted, it's nice to be able to change the IGN value you want with the tool; having it here in the Parameters window makes more sense.
The new feature is perfect and welkom. The ign tool must stay!
both stay. the new one is for customers or if u don't have a laptop with you. Well that never happens to me but
