strange problem with chipped ecu..
I chipped a P28 a few days ago. Nothing special, but when I put it in my car and turn the key it pulls all the injectors wide open and sets the fuelpump constantly on! The result is that I had 1.6 liters of fuel in my engine! What the f*ck can this be? Its doing it also without a chip in the socked. Nothing seems to be burned in the ecu. Anyone any idea what might be broken in this ecu?
computer is fucked.. frank remember it also happened with my ecu and my ostrich was fried too? MCU is done i couldn't fix it either i tried replacing the 7u0016 and that didn't help
My guesstimate: Dried out capacitor or something else causing the supply lines on the PCB down, probably in effect killing the voltage regulator. These ECU´s are getting pretty old and we will see defective ones from time to time. I always replace the capacitor that sometimes blows up, just in case... /Allan
May I ask, what capacitor is that? I'm going to pull my ECU when I do EBC and would like to replace known weak or tired components.Bindegal wrote:My guesstimate: Dried out capacitor or something else causing the supply lines on the PCB down, probably in effect killing the voltage regulator. These ECU´s are getting pretty old and we will see defective ones from time to time. I always replace the capacitor that sometimes blows up, just in case... /Allan
ST143A you have 3 of them on the upper left corner.. one should be related to fuel pump.. send me a mail so i can send you the circuit diagram of an p28/p30
