testing 0021r14 rom 0.0.59(offset/tipin/overall)
zex_cool
Post by zex_cool »
yes, thats why you told me to post in here. i didnt have this problem with the r13.
please post your injector, offset fv used, overall used, tip in. did you reselect the battery tables and started a tune from scratch?
you guys will by a lotto ticket today;) HINT
who wants to test today now tonight? that used r14 before?
zex_cool
Post by zex_cool »
yeah, everything is new. i sent you a email. and you have my cal form the other day...its the same one. Edit by calvin: 1000cc precision injectors 45FV offset -50% tps tip in
zex_cool
Post by zex_cool »
just tested with a new patch and the car drives very smooth with -28 tip-in! much better then before when it was at -50. thanks calvin. off topic: i love being able to talk to the creator of my ems over MSN! simply badass!!!
Maddog20
Post by Maddog20 »
D*mn that was fast. Zex_cool so all you did was update with the new patch or did you restart from scratch?
zex_cool
Post by zex_cool »
yeah same r14 0.59 with jst the new patch.
u need to post more info.. How is tip in during driving, idle, during hard shift, normal shift, what did you see with tipout... etc etc etc etc etc
My setup seems to be a bit diff. I have almost no tip in issues at all, the main problem I have is it goes (slightly) lean on low speed tip-in. I run 0 FV offset and 20% tip-in. It seems to idle better with this newer version too. I also noticed that when I start the car hot the idle does a nice rev to 1500 and slowly comes down to 1100 like a factory car would (minus the 1100 but I have it set there for the cams). Precision 1000cc injectors.
cool the improvement i did today is 100 better again. will send u guys the update soon
Cool, will this need a full retune again too?
no just tipin adjustment
greasemonkee
Post by greasemonkee »
Am I seeing things or is there a strange occasional leaning out occurring under part throttle? Also, I haven't been able to get the fuel cut down under 3000. I've set everything to 1300, but I haven't been able to get it to change.
Maddog20
Post by Maddog20 »
I have something similar but it happens at idle. after the car is warmed up NO Corrections involved and the idle A/F will be around 14.5 Drive the car around still no corrections and the idle A/F will be 15.0-15.3. I thought it was my battery offset..but it seems good to me. I have tried retuning the battery offset Starting the whole injector calibration from scratch (different Injector offset, battery offset) increasing the table fuel value
Y8-R14test.cal
(8.17 KiB) Downloaded 313 times
