decel fuel cut wont save? bug?
this is with actual version on force update right?
non-vtec
Post by non-vtec »
ectune version 0.0.2.2 r4 my rom version: 0.0.62 the issue is not when changing the value and closing the parameters window/tab. the value will remain that way as long as you don't exit ectune. the issue is when you change the value lower than 206mbar. save. exit ectune completely and restart ectune. once restarted and the cal loads you instantly see the red \"modified\" on the bottom. then when you check the decel fuel cut it always goes back to 206mbar. if you set it to anything higher than 206mbar it will save properly. anything lower it wont. hope that makes sense.
debugging with pro license and release version now;)
non-vtec
Post by non-vtec »
i never had this issue prior to the release of r3. something must have changed..??
fixed
Working for me now. Did notice though you have to move the cursor out of the box or hit the enter key for the value you entered to be saved. If you don't and just click save rom and close, then reopen the rom, the previous value entered is shown.
