Few issues I need help with.
Topher03
Post by Topher03 »
Just found out that the iacv is disabled in the ecu. I'll turn that on later and see what happens.
Topher03
Post by Topher03 »
Noticed at idle my iacv duty is like -38 % and no matter low much i change the iacv duty table it wont make it go down. As it warms up it keeps going into the - more. I have the duty at 0
Topher03
Post by Topher03 »
Can I email someone my tune and let them look at it and see that they think.
Topher03
Post by Topher03 »
Heres the current tune. Boost has already been dynoed and it great. This is a combo of the high and low boost tunes. OPlease take a look at it and tell me what yall think. 82mm b16 9:1 stock b16 head itr cams 1000cc injectors base fp at 38
low-high boost.cal
(8.19 KiB) Downloaded 599 times
looks good
Topher03
Post by Topher03 »
Then why am I having so much trouble getting it to start? If I give it gas to start it then let off it dies. But if i hold it around 2k for around 20-30 secs and let it off it will idle.
does your boost gauge read vacuum? Is it stable or does it bounce around? what are the readings at idle?
Topher03
Post by Topher03 »
I dont have a boost gauge, but I can log it and tell you...
Topher03
Post by Topher03 »
Well i noticed I have a vac leak so I swapped out tbs and not the car wont idle at all.
Topher03
Post by Topher03 »
Blake this is the tune from today
low-high boost.cal
(8.19 KiB) Downloaded 572 times
did you do all the things i said to do? do i have a new log?
Topher03
Post by Topher03 »
Did not do the valves. The set screw on the tb was holding it open so it was idling high. I drove it around some and it didn't die. Its idling around 900-1000. But its still only pulling like 9-11 vac
Topher03 wrote:Did not do the valves. The set screw on the tb was holding it open so it was idling high. I drove it around some and it didn't die. Its idling around 900-1000. But its still only pulling like 9-11 vac
do the valves when you can. I bet that is part of the problem. I was looking over your log, you need some part throttle tuning done.
Base fuel pressure of 38..... That's a little low for any injected system... Does the wideband show that the afr during this startup is okay? A few weeks ago I saved a mechanic alot of heartache diagnosing a no-start: the fpr was bad yet letting 42psi of pressure in the rail, yet, it wouldn't run until I told him to put his smog clamps on the return line.... Fired right up. Just food for thought.
Topher03
Post by Topher03 »
I'll try that Blake. Its the weather isn't too bad when I get off I'll get some more logs of this newer tune and e-mail it to you.
