Lean Protection Errors?
let me send a new version to u first... so there is no confusion
did u get the r3? test again please make me a log please..
I did get the r3, but it snowed a bit here so I will be testing tonight at the earliest, if not tomorrow. When should we be expecting the VSS fixed r3?
sohcd16y8 wrote:I did get the r3, but it snowed a bit here so I will be testing tonight at the earliest, if not tomorrow. When should we be expecting the VSS fixed r3?
fixed it already redownload.. if u want u can keep current. it shows the timer for lean protect 1.. countdown timer.. then u know for sure if lean protect is enabled the timer should be 0. VSS is my debug flag when testing :o
for my info; redownload from the last link you sent me? is it going to be the 0021r3.t0 file? I have already installed this one; so do I need to redownload the same one? (sorry for being confused)
same link download
Just got done testing and it works fine. I attached the log in case anyone wants to see it. Also I left the closed loop and ve disable disabled and just disable closed loop since my tune changed a lot with ve disabled. The o2 CEL didnt come on again though, so hopefully it was a fluke. Thanks Calvin!
Good test.elf
(465.63 KiB) Downloaded 426 times
lean protections works fine?
Like a champ!!!!
ok
joppez
Post by joppez »
I cannot set leanP to work. If i use setup like this it will Icut at minimum rpm (datalog you see is different run) Image Like this it will have Icut 4000rpm even on cruising and leanP led is not on. I have innovate MTX-L to D10 and its dead on.
I believe I remember seeing leanp 2 did not work correctly. Try just #1 and report back.
joppez
Post by joppez »
Now it doesnt do anything, i put max afr 12 on leanp 1 and i had little lean 12.8afr over 15psi and it didnt do nothing? I cannot put anything on \"cut rpm\" Is this setup right or am i doing something wrong? Pic of log here: http://joppen.kuvat.fi/kuvat/d16z6/EMS/ ... 1.jpg/full
joppez
Post by joppez »
Still not working, tryed different settings like max afr 10 and still no luck, this feature could save engine if working right so i want it. WB is working because im using WB closeloop.
joppez
Post by joppez »
Got it working, changed wbo2 from d10 to d14. But now log afr is not stable its oscillating little bit :(
