(ECT and VSS work!) Yet another s2000 cauge project [READY]
- Orthello
Finished the PCB design. It fits on 1.8 x 2.2 inch. (4,5 x 5,5 cm) It includes a 6 pin connector for 5V, GND, VSS in, VSS out, ECT in and ECT out. It also includes two ICSP connectors the load new firmware in each converter. Next steps... Printing Exposure Etching Drilling Assembling Soldering And then.... hopefully the PCB design is correct and the converters do exactly the same as on the breadboard.
Update and some modifications. After finishing the test hardware for ECT I experienced nervous readings again when the headlights (or other heavy users) were turned on. It (again) seemed that the ground of the cigaret lighter isn't the most stable one. So I decided to connect the ECT converter to the 5v and 0v of the TPS sensor. This works perfect! stable readings, very very few electronic parts are needed. Basicly.... microcontroler, 2 caps and a crystal for the clock pulse. And nothing more. Straight T tap for the ECT input and een straight connection to the S2000 ECT wire. And it works perfect. I decided to split the VSS and ECT converters. the VSS converter will be put at the back of the S2000 cluster. The ECT converter will be at the ECU. After a few days and km's of testing this turns out to be the best way to solve this issue. And... probably this is also the reason that modifry has two seperate converters. How Mark Lamond solved this... I'm not sure. I haven't seen any work he has done. But... my own work is very promissing. Now I have time to do some PCB changes. Because I have to wait for the microcontrolers to arrive. *SIGH* To be continued... but the end is near!!!
I found some cool stuff to have access to the 93C56 EEPROM in thecluster without removing from the PCB!!! Which is very nice because it is SMD mounted. There is a 'connector' next to the 93C56 with direct connections to all the pins of the 93C56. Pins are little bit shuffled, bur all direct connected. Red: Chip Select [CS] pin 1 Green: Serial Data Clock [CLK] pin 2 Light Blue: Serial Data Input [DI] pin 3 Dark Blue: Data Output [DO] pin 4 Pink: Power Supply [VCC] pin 8 & pin 6 Yellow: Ground [VSS] pin 7 & pin 5 Makes it easier to reprogram this EEPROM (ODO and mile/km select button)
But.... unfortunatly this 'connector' also is power supply to different other electronics, which started talking to the EEPROM too. So... removed the EEPROM from the cluster hardware. With some tweaking I was able to put it in my programmer and backup and change the content of the EEPROM. Enabled the MPH/KMH button, and added 200000 km to the ODO reading. It was 36000 and now reads 234000 km. So it matches the ODO reading of my CRX. For prove and a demo of the button: my YouTube channel
You'd gotta bet that there is some sort of RP jumper, or something you can remove fromt he board so that you don't have to remove the EEPROM to program it... It would be a gut suspicion here... but as for the new results, ROCK ON! Fantabulous work on your behalf!Orthello wrote:Red: Chip Select [CS] pin 1 Green: Serial Data Clock [CLK] pin 2 Light Blue: Serial Data Input [DI] pin 3 Dark Blue: Data Output [DO] pin 4 Pink: Power Supply [VCC] pin 8 & pin 6 Yellow: Ground [VSS] pin 7 & pin 5 Makes it easier to reprogram this EEPROM (ODO and mile/km select button)
It's WAY to suspicious. But I couldn't get it to work properly, so removing the EEPROM was the quickest and most reliable option in this case.( I had to be cousious not to corrupt the content of the EEPROM before a backup was made) Doesn't matter how... but my goal is achieved. Change ODO and enable KMH/MPH button.JaredKaragen wrote:You'd gotta bet that there is some sort of RP jumper, or something you can remove fromt he board so that you don't have to remove the EEPROM to program it... It would be a gut suspicion here...
Paper not ready yet, but.... I do have some pics... Finaly got everything in my car! outside (sorry for the blurry pic. long shutter without stand still doesn't work)
inside
S2000 cockpit
Cockpit in action http://www.youtube.com/watch?v=-m5Kpz5ARnk http://www.youtube.com/watch?v=aO1ORGRn_8U
That's so bad ass, so when you gunna offer a kit for us ectuners?
