Boosted K20 wrote:did u use eCtune boost controller?
    thanks for the kind words everyone.
   I actually have the eCtune boost controller but it was not hooked up when I went to the dyno. Right now boost is controlled by a Blitz EBC but will be replaced by the eCtune EBC when I get a chance to go to the track and do some test runs.  When I went to dyno the car I totally forgot to change the spring in the wastegate to a stiffer one, so the boost wasint staying steady at high RPM on higher boost levels.  when I get to the track Ill put a stiffer spring and test out the eCtune solenoid.
