new to ectune and got this error
butch11a
Post by butch11a »
just connected ostrich and updated to new firmware, then requested license, ostrich connected but i got this error... \"See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at 0&#382;&#65533;87&#732;&#338;&#8250;&#8221;i&#732;st&#382;s&#8250;s&#710;&#65533;.&#65533;&#339;&#382;81k&#338;&#353;gfeb&#353;yodv&#382;n.&#353;&#65533;&#8240;&#8220;&#8221;&#8240;&#65533;&#8224;&#710;(Int32 ) at &#376;h&#8221;6o&#65533;&#8240;x&#339;&#339;jk&#8250;7&#8240;fge&#352;.&#65533;n18bn&#8240;w&#8225;r&#8220;&#732;&#352;6&#65533;8&#8249;ur.gdu&#65533;7q&#8240;zk1o&#339;8ff&#352;sr&#8249;.o&#8240;2tr9&#8240;y&#65533;&#65533;15lx&#65533;g&#352;7g.Invoke(Int32 ) at &#376;h&#8221;6o&#65533;&#8240;x&#339;&#339;jk&#8250;7&#8240;fge&#352;.&#65533;n18bn&#8240;w&#8225;r&#8220;&#732;&#352;6&#65533;8&#8249;ur.&#8216;&#65533;&#352;&#8212;&#353;&#65533;&#8240;&#65533;&#732;(Object , ProgressChangedEventArgs ) at System.ComponentModel.BackgroundWorker.OnProgressChanged(ProgressChangedEventArgs e) at System.ComponentModel.BackgroundWorker.ProgressReporter(Object arg) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.1 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- Interop.MTSSDKLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/eCtune/Interop.MTSSDKLib.DLL ---------------------------------------- eCtune.XmlSerializers Assembly Version: 0.0.2.1 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.XmlSerializers.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging=\"true\" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.\"
butch11a
Post by butch11a »
tried it again this morning and its working now, dont know what happened, thanks.....this is why i switched to ectune, love the tech support....
did you receive the license?
butch11a
Post by butch11a »
Hi Calvin, I already had the licence when i got the error.
ef92b
Post by ef92b »
butch11a wrote:tried it again this morning and its working now, dont know what happened, thanks.....this is why i switched to ectune, love the tech support....
yes, support is top notch! :D Luis (butch11a)HCP? clyde here, newb with eCtune too. :) Congrats po for your new tool.
newb a.k.a clyde(pgmfi.org)
butch11a
Post by butch11a »
Hi Clyde, ef92, yup this is Luis, butch11a at HCP, switched to ectune since i had a hard time getting a smooth idle with my b18c5, t3/t4 turbo, 750 cc injectors and exedy carbon clutch. Maybe it was the very light flywheel which came with the clutch that made my idle erratic, datalog shows that injector pulsewidth at idle was jumping around at 1.5 to 2.5 ms and timing was 16 to 20 deg. When i loaded a base map on ectune this morning idle was as smooth as a stock motor and i can even lean it out to 15 to 18 afr when before it would only idle smoothly at 12.5 to 13 afr....now i can switch over to those 1000cc injectors and my gt35....
