eCtuned All Motor Car - 1st Place
An all motor car tuned with eCtune won the 1st place at NHRA Virginia ET 2. Car ran 11.7 1/4 mile. Thanks To Randy FYI: Car had big eCtune stickers... I'll post more info soon
- Boosted K20
whitfield-tuned
that is spectauclar i am making some eCtune stickers for cars that i tune with it .
WHITFIELD RACING INC 8455 LOMA PL. UPLAND CA 91786 www.whitfieldracing.com in house dynojet dyno EFI certified Authorized eCtune tuner PRO-TUNE
whitfield-tuned
excuse the spelling no sleep for a week!!
94 Honda Civic Hatch LS Sleeved Block 86.5mm Bore 95 mm Scat Crank Weisco Custom Pistons (Around 15.5:1 Comp Ratio) Custom Rods GSR Head (Port Flow) Oversized Valves Custom Cams from RLZ Engineering TI Springs Retainers RMF 4-1 Header Inline Pro Intake Manifold RC 440cc injectors (SAT) 50psi Fuel Pressure Walbro 255 Pump 75 mm Throttle body Custom 4\" Intake Pipe MSD Blaster 2 coil VP c16 116 octane Fuel eCtuned by RSTECH
CRX ALL MOTOR PR
CRX ALL MOTOR PR
Joey Misanthropy
rschoener
The Cams we original had were from RLZ. I think they were made by WEB cams. They broke after this race. We switched to Skunk 2 Pro 3 cams. Scat 95mm crank 86.5mm bore and Portflow head. 116 VP fuel this put down 262HP. The engine was originaly built by inline pro. We had some bad rod bearing wear and other random problem with this car. It just broke a rod and wiped out the bottom end. We are in the proccess of building a turbo setup for this car now. It had an ATS 4.9 final drive. with B16 gear set Quaife Diff and 24\" MH slicks. The car was not as consistant as we would have liked it. I will get the time slips later and post up the MPH and times. I remember it was 1.7 60' we wanted to try some 23\" slicks I think the 24's we a little tall.
[/img]
