Another night another list of bugs...
Here is my list of bugs from this evening of tuning... The IAT and CLT values turn red above certain values. If you change the display for temps to fahrenheit they are always red. Backspace key when editing a value does not work - you have to key over and use the DEL key. Editing the MAP value above a column once you've specified to display in PSI still asks for it in mbar. You cannot select a cell on the graph version of the fuel graph. I've tried right, left and double clicking the points but am not able to select them. I was also able to somehow key over and get an invalid index exception but I'm not sure how to reproduce the problem. TPS scaling does not work - it always reverts back to stock honda sensor. You cannot shift select cells when navigating in the graph mode. Normally you'd be able to hold shift down and use the up/down/left/right arrows to select a region of cells. -Michael
Re: Another night another list of bugs...
-IAT/CLT i know... just change the warning values in Tools Sensor Setup. But will fix this soon. -Advance Table: noticed it too. but fixed it already -MBAR scalar: Correct: You have to fill in mbar... I can change this though. I did this because i haven't wrote all forumula for different map displays to mbar. -TPS scaling parameter bug. Fixed already Just try to use Tools-> Tps calibration works better -Shift grap hmode: I know that. I tried to fix it a while back.. But took to much time. I'll look into againhackish wrote:Here is my list of bugs from this evening of tuning... The IAT and CLT values turn red above certain values. If you change the display for temps to fahrenheit they are always red. Backspace key when editing a value does not work - you have to key over and use the DEL key. Editing the MAP value above a column once you've specified to display in PSI still asks for it in mbar. You cannot select a cell on the graph version of the fuel graph. I've tried right, left and double clicking the points but am not able to select them. I was also able to somehow key over and get an invalid index exception but I'm not sure how to reproduce the problem. TPS scaling does not work - it always reverts back to stock honda sensor. You cannot shift select cells when navigating in the graph mode. Normally you'd be able to hold shift down and use the up/down/left/right arrows to select a region of cells. -Michael
