1988 honda crx si with 1991 honda crx si engine
highlandrim46
Post by highlandrim46 »
I dropped an engine out of a 1991 honda crx si into a 1988 honda crx si and discovered that the distributor plugs will not plug up. How do i get it to work????? Please Help!!!
~*C.A.N.Racing*~
Use your '88 si distributor.
highlandrim46
88 through 91 si distributors are the same so i tried that and it wouldnt work. The plug's on the si distributor are round and the plugs on the wiring harness are square.
~*C.A.N.Racing*~
If they are the same and you tried that, then there is something else wrong? Or the '88 dist is broken? What happend with the '88 dist?
Synoptic
Post by Synoptic »
are you sure you're not trying to plug a MPFI distributor into a DPFI CAR by anychance ?
